TC starter switch
TC starter switch
How to remove the TC starter switch cap? Looks like a difficult task because of little space. Do I have to remove the starter?
Re: TC starter switch
There are four very small screws holding it to the starter housing. Remove those, and the switch drops away. It is tight but not impossible. I suggest disconnecting the battery before working with the switch so you don't short between the starter cable and the frame.
Thanks for your help Steve!Steve Simmons wrote:There are four very small screws holding it to the starter housing. Remove those, and the switch drops away. It is tight but not impossible. I suggest disconnecting the battery before working with the switch so you don't short between the starter cable and the frame.
Jim
