Differential pinion oil seal replacement on TC
Posted: Tue Nov 24, 2015 6:47 pm
by Richard Michell
I have a significant oil leak from the pinion shaft as it emerges from the front of the diff casing. Otherwise, the diff seems fine.
I am contemplating replacing the current cap with the modified type from Moss/FTFU that contains a modern-ish rubber lip seal. Has anyone done this with the rear axle in the car? I have access to a two-post hoist.
Re: Differential pinion oil seal replacement on TC
Posted: Tue Nov 24, 2015 11:06 pm
by frenchblatter
I fitted a modern seal supplied by Roger Furmeaux in the UK.
No idea if it's oil tight yet. Give me a shout about next March :)
Posted: Wed Nov 25, 2015 1:48 am
by John Frederick Cockrem
I fitted one with success from the top through the tonneau floor, easy job and no more leaks.
John Cockrem TC 2268
Posted: Wed Nov 25, 2015 11:29 pm
by Richard Michell
Thanks John (and Norman). I will let you know how I got on - probably about next March also.
Posted: Sun Nov 29, 2015 1:17 pm
by Norman Golm
I have installed three Moss pinion seals kits with excellent results
