Checking Water Passages
Posted: Sun Jan 02, 2022 6:54 pm
Back in 2006 one of my TC’s was totaled. I bought it back from the insurance company with the intention of rebuilding it but life got in the way and it’s been on the backburner now for 16 years…until now. The main damage was to the body so the engine, transmission and chassis are in good shape…front axle was bent but since has been straightened.
The engine had been rebuilt a few years before the accident so it should be good…it still turns over easily and I don’t want to take it apart. I drained the block and the radiator shortly after the accident but I believe I should check and make sure the water passages are not blocked with crud before I start putting the car back together. Is there a quick and easy way to tell if the passages are clean without removing the head and if minor cleaning is needed is there anyway to do it without running the engine?
Thanks…
Thanks…
