Distributor Issue/Question
Posted: Tue May 17, 2022 6:10 am
I believe I have found the reason for my hot running and lack of power.
My distributor appears to have been installed 180 degrees out from correct. I checked the timing with a strobe light and found it running at a degree or two past TDC and the micro adjuster at full advance to get to that setting. The plug wire from the cap that is farthest away from number one cylinder is the lead that is sending spark to the number one cylinder. I have no idea when this happened but it likely been running this way for quite some time. For me, normally, that lead would be the lead that supplies cylinder number 4 with spark.
My question for all of you is this, is there anything I need to be careful of when dealing with this distributor? I know that there is a gear, instead of a pin, at the bottom of the shaft that must be encouraged to mesh on the reinstall and that makes me wonder just how you make sure you are meshing at the right point. My plan is to remove the distributor and reinstall with rotor pointing to number one cylinder with timing marks at the front of the engine lined up at TDC. I'll have the micro adjuster at midpoint and then do a static timing before a running fine adjustment. Fingers crossed!
I did notice the plug lead arrangement a while ago and thought it needed looking into but as the car was not on the road yet just continued to solve more pressing issues first.
Thanks in advance for any advice on this next bit of work. Report to follow once completed.
Lynn
Lynn
