TA/TB Seatback Braket Locations
ferricsteed
Post by ferricsteed » Thu Mar 17, 2016 12:54 pm
Does someone have dimensions on the location of both the bracket that attaches to the seatback and the bracket that attaches to the inner wheel arch? Also, what is the orientation of the inner wheel arch bracket, curved side up or down?
Regards,
Tim Bloomfield
TB0613
Louisiana
phil cassie
Re: TA/TB Seatback Braket Locations
Post by phil cassie » Sun Mar 20, 2016 1:43 am
Hi Tim I measured up my late TA and came up with the following dimensions not sure if they are original but looks and works ok. Distance from top timber of seatback to top of rectangular metal bracket 6'' The bracket is mounted on the extremity of the seatback. The seatback is curved but the lower corner of the bracket is flush with outside seatback edge. The whee larch bracket mounts curved side up rear screw 7 1/2 [seven and one half inch] from floor of cargo area and 9 3/4'' from sidescreen storage area. The front screw is 6 3/4'' from floor. Hope you can make sense of my ramblings, just contact me if you need more information.
Regards
Phil Cassie
TA2833
Silvan Australia
ferricsteed
Post by ferricsteed » Mon Mar 21, 2016 9:16 am
Many thanks for carving the time out to measure and sending the information. I'll take a picture and send back to you when completed.
Regards,
Tim Bloomfield
TB 0613
Louisiana
