towing a small caravan
Posted: Sat Sep 24, 2022 2:16 am
by jddevel
Has anyone tried or experience towing a caravan with a "T" series? I`ve a 1500TF that I`m exploring the possibilities. Research appears to show that a caravan of gross weight a little over 700 KG should be possible. There are a number of models that could suit our purpose.
Re: towing a small caravan
Posted: Sat Sep 24, 2022 4:54 am
by Ray White
Posted: Sun Sep 25, 2022 12:00 am
by jddevel
Hi Ray, Yes that`s the type. Or maybe even a "teardrop" design which are even lighter. If as I intend with more "freedom" regarding Covid 2 to 3 week tours can soon eat into funds relying on B&Bs etc. I realize with potentially hilly roads one with independent brakes would be advised plus possibly a upgrade to at least front wheel discs. It certainly would allow us to seek sunnier climes during those wet cold winter months and enjoy the car etc,
Posted: Sun Sep 25, 2022 9:32 am
by Ray White
I don't think you need to fit discs because the TF brakes should be sufficient to lock the wheels...but you might consider fitting a 1.9: 1 servo just to make it less of an effort. If such a modification appeals I would avoid the super cheapo Chinese copies and get a genuine Lockheed unit.
They are a lot dearer but should be more reliable,
Posted: Sun Sep 25, 2022 9:57 am
by jddevel
Cheers Ray. Will look into that. Must confess brakes no problem at the moment. Just concerned about potential fade problems in more "mountainous" areas
Posted: Sun Sep 25, 2022 10:25 am
by Ray White
I know they are expensive but I have replaced my original TC drums with Alfin types. They claim to reduce fade by dissipating heat...but I have yet to find out for myself.
We have some big hills here in Derbyshire !!!
Posted: Sun Sep 25, 2022 11:02 am
I've never done it but I know people who have. So it's certainly possible. I think I'd feel better with trailer brakes, either electric or surge brakes maybe.
Posted: Sun Sep 25, 2022 11:33 am
by Ray White
As a matter of interest, in the U.K., trailers and caravans under 750Kg are not legally required to have brakes. Unbraked caravans and trailers are usually attached to the towing vehicle with a rigid hitch so the cars brakes have to compensate for the added weight.
I would think a greater risk would be the light weight nature of the MG which could be easily flipped over should the caravan become unstable; should it suffer a tyre puncture/ blow out, for example.
Posted: Mon Sep 26, 2022 2:23 am
by jddevel
Mmm! Blow out. "Always looking on the bright side of life" hadn`t stopped to consider that although my wife has emphasized the effect of heavy lorries on fast roads. More to think about.
Posted: Mon Sep 26, 2022 4:22 am
by Ray White
jddevel wrote: ↑Mon Sep 26, 2022 2:23 am
Don't let the negatives outweigh the positives. If we dwell on all the bad things that
could happen we probably wouldn't do
anything.
Posted: Mon Sep 26, 2022 2:46 pm
by Bob Schapel
In 1983 I towed my TC race car behind my TC road car from Adelaide to the Geelong MG National Meeting. I built a light un-sprung car trailer for the purpose. The all-up AXLE weight was just below 750 kg. That trip is about 440 miles each way. I did it because I wanted to compete in both cars in the sprint competitions. It all worked out well, but I don't think I would do it again. I kept a long way behind other traffic because I was concerned that braking distance was my biggest problem. I think it was legal at the time, but I don't know if it would still be so now. The better brakes on TD/TF would be better for the purpose, but the wind resistance of a caravan might be worse? Trailer brakes would also be an advantage.
Bob Schapel
