Hazard Flashing Unit
Posted: Sun Jan 29, 2023 2:19 pm
by jddevel
Can anyone give me the recommended part number/unit to allow fitting of hazard flashing on my TC please.
Re: Hazard Flashing Unit
Posted: Sun Jan 29, 2023 7:20 pm
I know I've seen a write-up on this somewhere. If I can't find it then I can probably reverse-engineer my father's TC, which has a hazard circuit. It might take me a while to get over there and do that however.
Posted: Sun Jan 29, 2023 7:30 pm
by Norman Tuck
I installed a digital turn signal device that does hazard lights.
It is self canceling (timed) and works with LED or standard tailight/sidelamp bulbs.
It uses two standard momentary switches (doorbell type) for left or right turn signals. Press both at the same time for hazard light. It automatically deals with the brake light/ turn signal issue.
It replaces all OEM devices (flashers, etc.).
It needs a negative ground car, with the ignition switch ON to work.
I bought mine from Speedway Motors. It was a Pent-Star unit, but is now:
Speedway Hi-Tech Deluxe Turn Signal Module For Turn Signal Switch. Speedway Motors | #91064070
I wrote an article about my installation in my Club's (Abington Rough Riders) May 2009 newsletter which can be found at:
http://abingdonroughriders.org/ARR%20Ne ... 202009.pdf
Good luck with it. It works for me. Norman Tuck
Posted: Mon Jan 30, 2023 1:58 am
by jddevel
Thanks both. The reason for my requiring it is not only common sense but required for European travel.
Posted: Mon Jan 30, 2023 3:04 am
by Franz Tenbrock
Hithe best side in the web where it is explained how you can make it with one on-off-on switch is here
https://www.dkw-f5.de/werkstatt/licht-b ... er-teil-1/
With this information I made my own system and I use the switch in the position of the fog lamp switch, I don t have a fog lamp
I took a modern led switch so I have the control lamp in the same position, I printed a clear resin knob as the original mg knob , sprayed it once black, so it looks like the original fog switch but it is my direction light switch, the hazard switch is on position of the dashboard light switch, the dashboard light is on with the driving light..
No new switch on the dashboard and all legal now
Look to my blog here, there are some pictures
