Rubber, bonnet to cowl
ferricsteed
Post by ferricsteed » Fri Feb 24, 2023 5:34 pm
Easy questions, what type and size screws hold the rubber to the cowl which the bonnet rests on? Oval head screws without washers? Distance between screws?
I threw the old rubber away before measuring the distances.
Tim Bloomfield
End of winter in Louisiana
Re: Rubber, bonnet to cowl
Post by Duncan M » Fri Feb 24, 2023 6:05 pm
They did not use screws. A type of tack.
JonnyP
Post by JonnyP » Fri Feb 24, 2023 8:41 pm
Specification 259 calls for 24 off Panel pins 3/4” long.
Post by antijam » Sat Feb 25, 2023 1:32 am
Post by Ray White » Sat Feb 25, 2023 5:17 am
You are likely better off using pins that won't rust.
ferricsteed
Post by ferricsteed » Sat Feb 25, 2023 3:52 pm
Thank you! Pins it will be. Great pic showing pins. I'll install 24 pins equi-distant.
Post by Duncan M » Sat Feb 25, 2023 4:05 pm
Similar to a typical finishing nail in US, but shorter. Like these:
https://www.homedepot.com/p/Everbilt-18 ... lsrc=aw.ds
Post by antijam » Sat Feb 25, 2023 4:29 pm
Try these - 20mm long, and you'll have plenty of spares! ;)
Edit. Sorry, forgot you're in the States.
