EXHOURST GASKET
EXHOURST GASKET
REPLACING EXHOURST MANIFOLD GASKET DRY OR WITH SEALENT ON TC
Re: EXHOURST GASKET
Personally I always install dry and haven't had any issues. I've heard of people using sealer but I haven't found it necessary.
Re: EXHOURST GASKET
I used Loctite 5990 copper exhaust sealant on the joint between manifold and pipe. No leaks.
Re: EXHOURST GASKET
I used that stuff on a troublesome Studebaker once. It worked well.
