Anybody know anything about the 4 tranny mount bolts/and or screws? Seems I have 4 bolts (2 each side) and the left lower can’t be removed without jacking up the engine/tranny? Is this normal?
Brian W.
TC transmission mount fixings
Re: TC transmission mount fixings
It doesn't matter which way the bolt is, you can still pull it off the mount straight forward. Just leave the bolt in place. I just happen to have a TC in the shop at the moment with gearbox off and the bolt still there. Here's a photo.
Or are you trying to only replace the mounts without removing gearbox? In that case yeah, you probably can't do it without raising the gearbox or cutting the bolt.
- MG TC Gearbox Mount
- trans-mount.jpg (67.12 KiB) Viewed 1501 times
Steve:
O.K. That picture helps. Seems a bit wonky but with over 45 years wrenching on MGs, I can understand.
Brian W.
Brian W.
