petrol tank filler neck
dezwartj
Post by dezwartj » Sun Aug 27, 2023 11:29 am
I am the care taker of TC 5061 since 1969. The previous owner had a TA in parts and therefore I detected a few TA parts on this TC. I recently lost my fuel tank cap (pricey) and found out that the hinge pin that this cap is connected to suppose to be a split pin on TC's. On this TC it has a narrow long bolt that apparently vibrated loose, hence the loss of the cap.
My question is to any TA owner that reads this: Do I have a TA petrol tank??? I can drill the screw thread out install a regular TC split pin, but I just would like to know...
Thanks,
Josh
Re: petrol tank filler neck
Post by Steve Simmons » Sun Aug 27, 2023 11:43 am
The TA tank will have an extra fitting on the bottom for the reserve line. If you have only two fittings - one for fuel line and one for drain - then it's a TC tank.
Post by Rob Reilly » Tue Aug 29, 2023 6:15 pm
Here is the cap on my TA tank.
The entire cap unscrews to remove it.
and here are the 3 ports or fittings on the bottom.
main feed, reserve feed and drain
There is no level sensor.
Post by Duncan M » Tue Aug 29, 2023 10:18 pm
Quite a bit different than the TC. Late TC. Split pin is not original.
