TC Front Spring Mystery
Posted: Fri Mar 29, 2024 9:58 am
I'm in the process of rebuilding the front axle for TC 6984 and was surprised to find that the arc on the two springs is quite different- see photos. The car seemed to have the correct stance when I brought it home - we have not driven her other than on and off the transport trailer. I did find missing leaves in the rear spring though.
One sources suggests that the arc of the front spring off the car should be 1.85 inches. Interestingly for these two, one is 2" under the arc and the other is 3". Which is correct?
From the overall appearance of the spring, the higher arc one seems nicer, has taper leaves and the 4 clips of the original. The lesser arced one has only 2 clips and has square cut leaves.
