Tank Strap Hardware
rstarkweather
Tank Strap Hardware
Post by rstarkweather » Wed Jul 10, 2024 6:21 am
When attaching the bottom of the tank straps, am I correct in assuming there should be a nut (and perhaps a lock washer?) on the tank strap stud on top of the clevis that attaches to the rear crossmember, as well as a nut and lock washer underneath?
This seems to be the only way you can clamp this side of the clevis to the crossmember. (Using the standard bolt, lock washer and nut on the other side of the clevis.)
Tim Jackson
Re: Tank Strap Hardware
Post by Tim Jackson » Wed Jul 10, 2024 7:52 am
Tank strap setup on my TC
1946 TC0999 / XPAG 1638
restore note
rstarkweather
Post by rstarkweather » Wed Jul 10, 2024 3:23 pm
Tim:
Regular washers or lock washers?
Tim Jackson
Post by Tim Jackson » Thu Jul 11, 2024 8:01 am
Flat regular washers as I recall
restore note
