TA Slow Running Lever
Rogerg12P
Post by Rogerg12P » Tue May 10, 2016 3:49 am
Hi, has anybody got any good photo's of how the slow running lever, spring & anchor clip (NTG Parts A835, A835B &C) are fitted to the carb. I cant work out how the spring and anchor clip fit. Many Thanks - Roger
Re: TA Slow Running Lever
Post by Gene Gillam » Tue May 10, 2016 8:13 am
Roger,
This is for a TC but I would imagine it's close enough for you to use for the TA.
http://www.mg-tabc.org/library/slow_running_control.htm
Not sure if you're familiar with the Resources section of the website but there's a section called Technical that covers a number of questions about the engine, chassis, electrical, etc.
Gene
Rogerg12P
Post by Rogerg12P » Thu May 12, 2016 3:42 am
Brilliant - Thanks Gene
