Speedo drive
Posted: Fri Nov 04, 2016 1:57 am
by frenchblatter
I will have to replace the spedo drive in the gearbox over winter.
Can I tap the drive out with the gearbox top off or is it a gearbox out job. I've tried pulling it out but it won't move.
Thanks
Re: Speedo drive
Posted: Fri Nov 04, 2016 3:07 am
by dirk w dondorp
sticky gasket!
Re: Speedo drive
Posted: Fri Nov 04, 2016 6:32 am
by frenchblatter
Morning Dirk,
I do sometimes suffer from sticky gasket. Other times from wet joints.
Re: Speedo drive
Posted: Sun Nov 06, 2016 9:21 am
by Gene Gillam
Norman,
Not sure you can get to it from the inside but I've never tried.
Take a blunt (flat faced) punch and tap the sides of the drive flange from side to side (maybe try some 50% ATF/acetone mixture to soak around the edges first. Once you get it moving you should be able to wiggle it out. The other option is to take a knife edge and tap it in between the drive gear flange and the transmission.
It will come out!
Gene
