Location of Gas Tank rubber mounting set (5 pieces)
Posted: Mon Aug 14, 2017 10:00 am
by Ron Zeraldo
While my gas tank is out being cleaned, sealed & pressure tested, I thought I would install the ‘5 piece rubber mounting pads’ for the tank on the frame rails & the body back board. Can anyone tell me the exact location of the top horizontal rubber pad & the two left/right vertical pads. If my memory serves me correctly these pads were all screwed in place (counter sunk heads). My tub is completely new & hence no markings from the original pad set.
Your help is greatly appreciated!
Ron
TC5911
Re: Location of Gas Tank rubber mounting set (5 pieces)
Posted: Mon Aug 14, 2017 1:14 pm
by Tim Jackson
I don't have dimensions, but this photo might help. I think the rubber pads are glued in position, not screwed.
Posted: Mon Aug 14, 2017 4:23 pm
by Ron Zeraldo
Thanks Tim that will help!
Regards,
Ron
Posted: Tue Aug 15, 2017 3:43 pm
The top horizontal piece of rubber shown in the pic above was actually two separate pieces in my TC. Near where they meet in the middle was a flat headed wood type screw on either side. The screw's were installed so the flat heads were down below the surface of the rubber. I do not recall if there was another similar screw for each of the vertical pieces. I think there was. With so few screws used, I would think some sort of glue was also used at the factory. Maybe even wet paint?
Posted: Tue Aug 15, 2017 4:17 pm
by Ron Zeraldo
Hi Duncan, thank you very much for the information...it certainly has helped!
Regards,
Ron
