TB Inner Dash Mounting
ferricsteed
Post by ferricsteed » Fri Sep 29, 2017 10:43 am
What all holds the inner dash in place? I am particularly interested in the underdash metal braces that my TB is probably missing.
Tim Bloomfield
TB0613
Humid Louisiana
cdrolshagen
Re: TB Inner Dash Mounting
Post by cdrolshagen » Sat Sep 30, 2017 12:53 am
Hi Tim,
hope that helps,
cheers Carl
Tim Jackson
Post by Tim Jackson » Sat Sep 30, 2017 1:28 pm
Another angle for a TC. Zoom in to see the two supporting brackets and fastener positions
1946 TC0999 / XPAG 1638
restore note
ferricsteed
Post by ferricsteed » Mon Oct 02, 2017 9:19 am
Thank you Tim and Carl. I am missing these two brackets. It looks like a slotted screw goes through the inner dash and through the metal bracket and held in place with a nut. The other end of the bracket fastens up to the bulkhead is less obvious. It looks like it could simply have two slotted wood screws for each bracket or it could be bolted with the through bolts that hold the scuttle to the bulkhead. Would you let me know. Excellent pictures by the way.
Regards,
Tim Bloomfield
TB0613
Louisiana
cdrolshagen
Post by cdrolshagen » Thu Oct 05, 2017 4:13 am
Hi Tim,
the brackets are not bolted to one of the bulkhead bolts,
attaches a picture you can spot the bracket bolts, all bolts are countersunk slotted 5/16 BSF
cheers Carl
