TC Fuel Tank
Posted: Thu Mar 29, 2018 10:35 am
by TBrad
I’m missing something trying to remove the gas tank. I can move it, but it looks like it is secured into the fenders were the two rubber bushings are on the side of the tank. I hate trying to force something. I removed the straps and the spare tire carrier along with the fuel line. I’m missing something. There is a bolt through the fender well. I thought that just held the rubber bushing in place. Does it go all the way into the tank? Are there some other hidden bolts or am I just not pulling hard enough?
Re: TC Fuel Tank
Posted: Thu Mar 29, 2018 11:23 am
There is a captive nut that the bolt threads into on each side of tank. The Moss catalog can be of use to show this.
https://mossmotors.com/gas-tank
Re: TC Fuel Tank
Posted: Fri Mar 30, 2018 6:28 am
by TBrad
It turns out the "builder" used studs instead of a bolts to attach the the tank to the fenders. I resorted to the double-nut technique to extract. Now it's off to the repair shop.
Re: TC Fuel Tank
Posted: Fri Mar 30, 2018 7:33 am
by TBrad
Split pins to hold the bottom fuel tank pads to the frame?
