RF95/2 Control Box Issues w/TC6736
Posted: Fri May 04, 2018 7:25 pm
TC Electrodynamic Experts,
Been wrestling with this box for 2 years. Had it transistorized. Battery registers 12.5v
1. D terminal shows 2-4v
2. F+D up to 32 v on hi rev
3. Manual settings with feeler adjusted for both regulator and cutout
4. Connect A+A1 and measure up to 35v on F and 12-13v on D.
5. Reconnect A and A1 wires to posts. Block off cutoff contacts and turn regulator top screw until 15-16v on F, about 12-13 on D. Regulator contacts are buzzing with a bit of white spark. Rev up and contacts will get sparky like a weld rod and F will go to 35v. Is regulator OK to spark like plugs all the time???
6. Adjusted cutout screw in and out without any degrade in voltage, but coil did energize and meet contacts.
7. Concerned it may be going haywire, even tho amps are only 3-4, I shut it down. But with key OFF, Ignition light is still on. If I screw down cutoff top screw coil will release and light goes OFF. BUT when I restart engine, light remains ON until I unscrew pressure so that coil has enough to close contacts.
I have read every thing I can find on the net and still can't get this right
Bob Wills
Bob Wills
