TC Rear Brakes and Hubs
Posted: Tue May 15, 2018 3:27 am
I've been workikng on a long-dormant TC, where the rear brakes were - as almost always - soaked with differential oil. Unfortunately, the axle shafts had already been welded to the hubs, and the axles themselves had a dangerous bit of twist where they seat in the spider gears. I got a replacement set of tapered axles and hubs (already assembled) from Bob Grunau, and they are superb!
I got the other parts I needed from Abingdon Spares, Doug Pelton of From the Frame Up and Roger Furneaux in the UK, including a set of the bearing housing nuts with integral oil seal to keep things dry. Doug's very helpful assembly video made sure that the spacing was right, and everything bolted right up. The only thing I did that he did not mention was to lubricate the nut seal with a little grease, to prevent start-up burning of the seal.
The axles and hubs are beautiful work, and the tapered design should keep things dry. Thank you, gentlemen!
