Manifold studs
Posted: Sun Sep 23, 2018 4:47 am
by Mark Robinson
Should I be screwing the longer end or the shorter end of the manifold studs into the block? Thank you.
Regards
Mark
TC4157
Re: Manifold studs
Posted: Mon Sep 24, 2018 1:06 pm
by Tom Lange, MGT Repair
Niether - if you mean the long studs to hold both instake and exhaust manifolds, the shorter end goes into the head, not the block. The short end of a stud goes into the permanent part - the short end of the head studs go into the block, the short end of the exhaust manifold studs go into the exhaust manifold flange, and the short end of the valve cover studs goes into the head.
Re: Manifold studs
Posted: Tue Sep 25, 2018 1:17 am
by Mark Robinson
Hi Tom. Yes I meant to say head rather than block. That's really helpful, many thanks.
Regards
Mark
