TB Body and TABC spares lot
Buy and sell M.G. parts and related goods.
craig.cootsona
Post by craig.cootsona » Thu Apr 20, 2023 5:14 pm
****Parts are all sold, thank you*****
I have stored a TB body and many spares that were not used when rebuilding my TA special. Please note, this is not a complete car as a chassis is not included! You will need to source one to make a complete car. I can provide a contact for that if you wish. It's time to find a home for them. I would like this to go as one lot because I want my shelving back for other projects. Asking $2500 for the lot or make an offer. I'm motivated to move them along.
The parts conditions are generally rebuildable, with some surface rust. The wings have surface rust and an occasional hole where they meet the body tub, but generally still solid enough to bolt on, not swiss cheese. Doors have filler on the steel but wood seems solid enough. Bonnet is in good condition.
The list includes:
Complete TB roadster body from from TB0501 (Type B270 #2015/10765)
Bonnet,
Rad shell
1250 morris/wolseley bare MOWOG block 22500 3APR39 , cam, sump, crank, flywheel, misc other parts disassembled
’39 Morris/Wolseley/MG head 22 952,
Exhaust manifold,
TC gearbox and remote assembly,
SU carbs, intake manifold,
Complete set of TA brakes drums and backing plates,
Spare wheel carrier with knockoff
Set of 5 19” center lace wire wheels with old tires mounted (still hold air for rolling around the shop),
Firewall, footramp with tool boxes and old liners, rear fender liners, new set of replacement body wood, wings, 2 front aprons, TA/TB running boards, corner and rear compartment brackets
Windscreen frame, windscreen,
New exhaust,
2 Dash woods
Misc dash switches (no tach or speedometer),
Wiper motor and connecting rod,
MG Abingdon sill trim plates,
Upholstered seat bases and back,
Complete top with bows,
Complete side curtains, misc dash switches
4 old leaf springs
Fuel tank and straps
2 large 8" Lucas headlight bowls (deeper bowls than 140s)
Last edited by craig.cootsona on Fri Nov 24, 2023 8:17 am, edited 1 time in total.
craig.cootsona
Re: TB Body and TABC spares lot
Post by craig.cootsona » Fri Nov 24, 2023 8:16 am
Parts are all sold, thank you!
