Used and reasonable for TC wheel truing set-up. Located in Illinois.
Not for road use, just good enough to mount the wheel and spin it. Old mating spinner a plus!!
Thanks. Marv TC5141
Wanted: TC Hub, Front preferred but can make a rear hub work
Re: Wanted: TC Hub, Front preferred but can make a rear hub
Marv,
Could you adapt an MGB hub for your purpose? B splines fit the 19" TC wheels but would require sourcing an MGB knockoff. I used a B front hub to make a tire changer.
Cheers, Bill
Cheers, Bill
- TireChanger.jpg (128.31 KiB) Viewed 5547 times
Hi Bill:
I was thinking that maybe an "A" or "B" hub might work. I'll have to look in the back room junk pile, I think I've got some of each.. Also have a couple Austin Healey hubs somewhere to, just haven't made time to dig them out.
Cheers. Happy Holidays..
marv
marv
The splines and tapers are all the same on MG, Triumph, Austin Healey, etc. Jaguar and some others are larger. Threads are 12TPI on most hubs before early 60's and 8tpi after. So you only need the matching spinner.
Yep, thanks Steve. Think I got it whipped once I dig in the junk pile!
Cheers
Cheers
Done and done! old Healey hub and spinner found in junk pile. Will work out great. Thanks Bill and Steve for jogging my grey matter into place.
