WANTED: 8 In Headlamp parts (not buckets), and other TC Part
Buy and sell M.G. parts and related goods.
Kameron M
Post by Kameron M » Thu Apr 14, 2016 5:10 pm
Hello,
Thought I would take a moment to type out a list of TC parts that I am actively searching for:
1- 8 inch headlamp lenses, reflectors, and trim rings (all I have is the 7 in trim ring) - A pair of 8 inch complete buckets that are dinged/dented/etc would work well also. I have found lenses on Ebay before, but never the ring or reflector parts.
2- Tachometer reduction gear
3- TC brake master cyl. "heat shield"
4- Speedo & Tach cables (probably will have to buy these new)
5- TC Gas Pedal.
6- The long brass lever on the TC Carb shaft close to the front carb on the rotating shaft. I believe this is the throttle lever.
7- TC radiator supports.
8- TC tonneau cover (complete, or just the metal hoop supports for it)
I will keep this list rolling for a while as I find, and need more parts.
epicsurf
Re: WANTED: 8 In Headlamp parts (not buckets), and other TC
Post by epicsurf » Sun Jun 12, 2016 5:36 pm
I should have the headlight buckets, reflectors and trim rings. I have two that are in mint condition and at least one that is dented. I will also look for some of the other items. Feel free to text me at 321 720-0241 and I will text you back some photos.
Post by Marv » Tue Jun 14, 2016 6:32 am
I've got a spare tach reduction gearbox - new
Marv TC5141
