Crane, now Comp Cams Roller tappet camshaft kits: Stock replacement, street performance, S/C or normally aspirated as well as race cams. includes, steel billet Roller cam, roller lifters, HD Chrome Moly push rods, " Super clean wire" CNC coiled,stress relieved, shot peened, & heat set valve springs,alloy steel spring retainers & lower locators. $1995. Roller cams will outperform any flat lifter cam of the same duration, with a wider power band.
Harland Sharp roller rocker arms, $ 525 per set, includes socket head pedestal bolts with high collar lock washers.
CSI ignition distributor dealer, all MG units in stock. https://csi-ignition.com/ MG t type $ 430. MGA/MGB $410. Many other make also in stock.
Custom Swirl polished Stainless-steel 37 & 35 mm valves with manganese bronze guides and cotters $ 295.
Teflon Positive stop valve stem seals $ 38.
And more
All my products are Unconditionally guaranteed
Roller camshafts are a period correct up grade.
Len Fanelli
Abingdon Performance
laf48@aol.com,abingdonperforma@aol.com
914-420-8699
