Altette Horns
Altette Horns
Post by Steve Simmons » Tue Oct 29, 2013 5:02 pm
I have just run across an Altette horn that looks identical to the one on my TC, except that there is no depression in the rear. Other minor differences are a single nut on front instead of double, and a thicker mounting bracket. Otherwise they look the same.
Does anyone know what type of car this horn would be appropriate for?
Altette Horn
Altette Horn
Altette Horn
Altette Horn
Altette Horn
Altette Horn
Rick Waters
Re: Altette Horns
Post by Rick Waters » Tue Oct 29, 2013 5:17 pm
My TC Altette does not have the depression--perhaps it's not the right horn, but my impression is that both styles were used interchangeably. Anyway, it hoots, and scares the chickens out of my path!
Incidentally, I had to do some work on my horn, to correct some previous well-intentioned work by a previous owner, and found "Taff the Horn" to be a great source of info and parts.
Re: Altette Horns
Post by Gene Gillam » Tue Oct 29, 2013 8:22 pm
Steve,
Google Altette horn - these were used extensively on motorcycles as well as cars.
Re: Altette Horns
Post by Steve Simmons » Wed Oct 30, 2013 10:04 am
Thanks, I know they were pretty universal but my question is more about what models of M.G. (if any) would this horn be appropriate for. I suspect TA through early TC. The Altette site does have a lot of info but it's pretty hard to find exactly what you're looking for.
timberstone
Re: Altette Horns
Post by timberstone » Mon Jan 06, 2020 6:26 pm
From TC's Forever (p 203): "The Lucas Altette HF1234 horn appears to have come, like most other TC equipment, in two varieties. Early ones have a solid round body [as pictured below - from the back]
while later ones sported a sizeable chunk out of the top of the body [as pictured in the earlier post above]
"... [there are] distintive small acorn nuts around the rim."
Octagonally yours,
Boxley (Robert and MGTC0820)
Re: Altette Horns
Post by bloodysalmon » Tue Jan 07, 2020 1:57 am
all I can add is that I thought the cut-back bodies where the earlier type and the rarer to find! :roll:
ROGER FURNEAUX
Re: Altette Horns
Post by ROGER FURNEAUX » Sun Jan 12, 2020 5:58 am
And all I can add is that they might look pretty, and they sound loud in the garage, but on the open road they are as much use as a chocolate teapot! I fitted a Klaxon type horn on the bulkhead above the RF91, and that really makes dozy pedestrians jump :lol:
Roger
Warmuthb
Re: Altette Horns
Post by Warmuthb » Tue Apr 07, 2020 3:14 pm
I think early ones had a pressed steel case, later went to cast iron? Maybe not, so don't rely on this.
Brian
Re: Altette Horns
Post by Tom Wilson » Tue Apr 07, 2020 5:16 pm
Check out taffthehorns.com. Loads of info to answer your questions.
Tom
Re: Altette Horns
Post by Steve Simmons » Tue Apr 07, 2020 5:52 pm
Thanks all, but this original question was from 2013! Things really do live forever on the internet. :)
