Locating the seat frames
LaVerne Downey
Post by LaVerne Downey » Wed Apr 02, 2014 5:13 am
I'll be securing the new floor boards after I get the TC on it's new tires and off my lift. A little welding including fabricating brackets from the frame to the muffler. I'm wondering what the best way to locate the seat frames on the floor boards might be, I have some idea but would like yours. Also should I bolt through the floor or get some T nuts for the wood?
LaVerne
Tim Jackson
Re: Locating the seat frames
Post by Tim Jackson » Wed Apr 02, 2014 1:42 pm
As the seats slide, the position of the runners isn't critical. Here's a photo of mine, secured to the floor boards with wood screws.
Tim
1946 TC0999 / XPAG 1638
restore note
ian fletcher
Post by ian fletcher » Wed Apr 02, 2014 11:07 pm
Hi I have set in Tee nuts which are obviously much stronger that the original wood screws used. The advantage is that you can remove the seat sliders to fit carpets or for maintenance as many times as you like without fear of them pulling out like the wood screws and also you can fit and remove them from the top without trying to stop the nuts under the floor from turning!
Post by Gene Gillam » Fri Apr 04, 2014 9:16 am
Agree with the t-nuts.
ian fletcher
Post by ian fletcher » Mon Apr 07, 2014 8:10 am
Just measured position of my hinges which were marked out from an original floorboard. The edge of the hinge is
2 3/4 inches in from the transmission tunnel and the front edge of the hinge is 21 inches from the front or 27 3/4 inches from the back of the floor board. The seat sliders are obviously parallel to the transmission tunnel. Hope this info is useful.
LaVerne Downey
Post by LaVerne Downey » Mon Apr 07, 2014 11:26 am
Thanks fellows,
Should help a bunch when I get back at the TC. :thumbs:
