I need an image of the fast idle spring set up
LaVerne Downey
Post by LaVerne Downey » Mon Apr 21, 2014 3:18 pm
I have all the pieces (I think) but I don't see how the spring should be installed. A couple of clear pictures would be most appreciated.
Thank You,
LaVerne
Tim Jackson
Re: I need an image of the fast idle spring set up
Post by Tim Jackson » Tue Apr 22, 2014 11:31 am
Here are a couple of photos of the slow running spring set-up.
Regards,
Tim
1946 TC0999 / XPAG 1638
restore note
LaVerne Downey
Post by LaVerne Downey » Wed Apr 23, 2014 7:15 am
Thanks, There is way too much resistance with the spring installed so I believe I will leave it off unless somebody has a good reason why I shouldn't.
