pieces fell out of this one when I took the cover off and it's not exactly like the ones on my TD and TF. I like to see an image on the inside on one to see if I can possibly repair this one.'
LaVerne
I know I'm needy...sorry...need another image fuel sender
- LaVerne Downey
- Gene Gillam
Re: I know I'm needy...sorry...need another image fuel sende
JB weld the cover on and use a stick to check fuel level. It won't leak and will be more accurate.
Gene
Gene
- LaVerne Downey
Lol..I went to a lot of trouble to get the low fuel light wired in....the damn thing is gonna work when it rolls out of my shop....soon I hope. I did a half assed attempted at a repair yesterday....I think a replacement is in it's near future.
- dirk w dondorp
Good luck, and be prepaired to repair it again and again, keeping you busy, as this monkey metal construction will keep on leaking! Gene's suggestion is OK, I even put a blind flange on the tank and use the warning light for low oil pressure, much more important than 10 Ltrs fuel left in tank.
