Just had another brain-storm.
Seems to me that one could purchase a "stock" size racing fuel cell of a size which could be mounted in the space beneath the "floor" of the luggage area, then linked via a hoses to the existing tank's filler neck and outlet. "Stock" sizes can be bought from several suppliers at prices as low as about $200 US. The only obvious drawbacks I can see to this are these:
1) The size of the tank might be quite limited -- there may be only enough room there to hold a few gallons of fuel. (Anybody happen to know how many cubic inches there are in a gallon?)
2) One would have to give up the fuel level indicator (That doesn't seem to be a major sacrifice, judging by all the reports of unstoppable leaks I've read. BTW, the other two ideas I threw out earlier today would also call for this "sacrifice")
3) One would have to figure out a way to rig a tube/hose from the cell through the bodywork to the filler port on the existing tank, or put up with having a filler port within the passenger area . (That prospect doesn't thrill me overmuch)
That about does it for me, for now. I'll be interested in hearing reactions from the list members, but please be gentle; I have been know to bruise easily, and to hit back, as well!
Regards,
Carl Fritz
Re: Another thought on fuel tanks
- Geoffrey WHEATLEY
Hi Carl,
Looks like I'm having a busy day on this medium but...
Question..A simple one:
Why not buy a replacement fuel tank they are around $345 in the UK less when you take off the VAT . I have the supplier who makes to order even in stainless. A lot easier than all this cell stuff! I purchased one at Beauliue last year and it is great. You know the simple way is often the easy way to most problems in the long run.
Regards Geoff
Regards Geoff
