Re: Pistons Required .080 Over
- Greaves, Tammy
I have sent a few E-Mails about and made a few calls attempting to locate anyone..or any company ..that has any .080 over pistons for sale. Can anyone please help me out. My motor is apart at a machine shop and the pistons ..or lack thereof..is holding the project up. Abingdon Spares has them on back order as does Naylor Brothers. Moss apparently does not stock them any longer. I am thinking I may have to go with Nissan pistons if none of you are able to help!
Thanks in advance.
Rob Greaves
Ottawa, Canada
P.S. - I stuck that last sentence in as I figure that will ensure I get at least a few responses!
Thanks in advance.
Rob Greaves
Ottawa, Canada
- JOHN SWANLAND
JP Pistons in Australia made my TC pistons. They do have a web site, and a web search should reveal the URL.
John Swanland
Melbourne Australia
Please note new e-mail address:
john.swanland@wesley.vic.edu.au
John Swanland
Melbourne Australia
- PMS GB Ltd
Unless you are desparate for a few more cc, why not just simply sleeve the block?Message text written by "Greaves, Tammy"
Clive Sherriff
P.S. You mean there IS a Nissan piston that fits??? Wow!!!! Goodie!!!!
- CVMGA@aol.com
Rob,
Try Egge Obsolete Engine Parts in California. Their number is 1-800-866-3443. I deal with Jim. They will either have the pistons on the shelf or they can make them. So far, I have had great luck with their parts! Note, you will have to ask for rings separately.
Another option, of course, would be to sleeve your block and fit a less oversize piston. . .or even standard size pistons.
Good Luck,
Bruce Woodson
Good Luck,
Bruce Woodson
- Skip Kelsey
Rob:
I have .080 piston sets with pins and Deves rings for $195.23 per set, including shipping.
Skip Kelsey..............................
- bgthomas@earthlink.net
Hi Rob
When I had the same problem ( no .080 pistons to be found) about 10 yrs ago with my TD, I went to .100 over. These were off the shelf and the extra bore brings you up to 1366cc for a little extra power. Later, you can always sleeve it back to 1250 if you ever had to.
Bob TC EXU 7388
Bob TC EXU 7388
