Can anyone tell me the original weight of the TC flywheel? I have dismantled the engine and I am now planning for the engineering work. The pistons are +20 but the crank has not been reground (52mm and 45mm) but I believe has been replaced (168557 which is the later crank)
Regards
Nick Fitzhugh
TC Flywheel Weight
- Nick Fitzhugh
Re: TC Flywheel Weight
If I recall correctly, it's about 22 pounds. I lightened mine down to 16 and it's still perfectly drivable.
- Gene Gillam
See Bob Grunau's drawing on lightening the flywheel in the Resources section of the website.
