After trying multiple things, with no success I need a little advice please. On my TC, I am shimming/adjusting the lower hinge. The front top tip of the door needs to come down a 1/4", and there is too much of an air gap between the two sections of the hinge...
At this point, I have a 1/4" of air space between the two halves of the hinge (too much, right?)
There is also 1/8" shims on both the OUTSIDE parts of the hinge (one door side one hinge post side)
Any suggestions on what to ad or take away please?
Thanks, Pat
PS: where do I go on this web site to change my password?
Need advice on shimming lower hinge
- Gene Gillam
Re: Need advice on shimming lower hinge
pat,
Suggest you remove all shims and start from scratch. Normally to lower the front of the door you'd shim the top hinge out from th back of the body, pushing the door forward and down.
Gene
Gene
The gap between the two sections of the hinge may be about right, not sure that it makes any difference. If your shims are on the lower hinge, take them off as Gene suggests and see what you have.
