TC starter switch
jameshglueck
TC starter switch
Post by jameshglueck » Fri Sep 04, 2015 8:40 am
How to remove the TC starter switch cap? Looks like a difficult task because of little space. Do I have to remove the starter?
Re: TC starter switch
Post by Steve Simmons » Fri Sep 04, 2015 8:45 am
There are four very small screws holding it to the starter housing. Remove those, and the switch drops away. It is tight but not impossible. I suggest disconnecting the battery before working with the switch so you don't short between the starter cable and the frame.
jameshglueck
Post by jameshglueck » Fri Sep 04, 2015 8:50 am
Steve Simmons wrote:There are four very small screws holding it to the starter housing. Remove those, and the switch drops away. It is tight but not impossible. I suggest disconnecting the battery before working with the switch so you don't short between the starter cable and the frame.
Thanks for your help Steve!
Jim
