Crankshaft oil slinger problem.
Post by Ray White » Sat Jul 18, 2020 3:51 am
I am unable to locate the oil slinger. Seeing that the sprocket is as far back as it will go and the chain seems straight, what do you guys think?
Re: Crankshaft oil slinger problem.
Post by Franz » Sat Jul 18, 2020 7:51 am
Hello Ray,
find some pictures, maybe this you looking for
Post by Steve Simmons » Sat Jul 18, 2020 8:06 am
If I recall correctly, the slinger is held tight by the crank pulley. So then it shouldn't be an issue. Maybe someone else can confirm. Try putting the pulley on with sump removed and see if it smashes down on the slinger.
Post by Ray White » Sat Jul 18, 2020 8:09 am
Thank you Franz but it does not show how to secure the slinger using the 'cut out' which I presume should sit on the end of the woodruff key. I could either leave it out or try and fix it to the sprocket.
Perhaps it would be held firmly in place by the end of the pulley?
Post by Tom Lange, MGT Repair » Sat Jul 18, 2020 8:42 am
The slot is just there to enable you to slip the slinger over the crank nose with the key in place. The pulley holds the slinger tight.
Post by Ray White » Sat Jul 18, 2020 8:54 am
Thank you Tom. You have answered my question perfectly.
Sometimes I can't see the wood for the trees!
Ray White.
(well meaning amateur!)
Post by Franz » Sat Jul 18, 2020 12:08 pm
You can see on the drawing that it isn’t fixed somewhere. I made last year the engine new and was lucky to find this drawing in the book MGTC forever because this slinger was not in the engine.
Post by Ray White » Sat Jul 18, 2020 1:57 pm
Thank you Franz for your advise. You have been most helpful.
