Crankshaft oil slinger problem.
Re: Crankshaft oil slinger problem.
Hello Ray,
find some pictures, maybe this you looking for
- EAF344C4-DB3C-4502-A422-4AF41345F286.jpeg (134.56 KiB) Viewed 1962 times
If I recall correctly, the slinger is held tight by the crank pulley. So then it shouldn't be an issue. Maybe someone else can confirm. Try putting the pulley on with sump removed and see if it smashes down on the slinger.
Thank you Franz but it does not show how to secure the slinger using the 'cut out' which I presume should sit on the end of the woodruff key. I could either leave it out or try and fix it to the sprocket.
Perhaps it would be held firmly in place by the end of the pulley?
The slot is just there to enable you to slip the slinger over the crank nose with the key in place. The pulley holds the slinger tight.
Thank you Tom. You have answered my question perfectly.
Sometimes I can't see the wood for the trees!
Ray White.
(well meaning amateur!)
Ray White.
You can see on the drawing that it isn’t fixed somewhere. I made last year the engine new and was lucky to find this drawing in the book MGTC forever because this slinger was not in the engine.
Thank you Franz for your advise. You have been most helpful.
