I have a set of TC Headlight Cradles. slight surface rust discoloration only, will clean up nicely with a media blast and paint of your choice. ( I can do this for you and prime with acid etch primer, if desired @ $40.00.) the pair can be had for $160.00 plus shipping. I'd rather not break them up but if you only need one, you can have it at $90 your choice L or R. Slight bending of one stud - lower bracket in pic.
Marv Proctor TC5141
I also have a nice set of fender braces in much the same condition...
TC Used Headlight cradles for sale
Re: TC Used Headlight cradles for sale
Hi Marv,
Where are you located and how much would you want for the fender braces?
Located in Rockford, Illinois, I have posted three pictures. They are straight with no damage nor repairs, they have light surface rust only, needs media blasting and a coat of primer (acid etch). Abingdon Spares has used ones listed at $135 each, I'd sell the pair for $200 plus actual shipping. If you'd like, I'll media blast them and put a coat of acid etch primer on them for an extra $30.
Max, I said Abingdon braces were used, I assumed that and don't know it for sure, they usually have the word "used" after a part. Moss offers them as well at $130 each. Moss is not noted for anything other than aftermarket reproductions. I have no idea as to quality of the usual suppliers. Doug Pelton has them listed as well at $127.40, don't know if his is used or not. Choice is yours!
Cheers,
Cheers,
Depends on which one you're looking for but there is a set on eBay at present (eBay item number:
331729021668) one is OK, the other is pretty badly buggered up , bent, broken and welded. Have a look at those and you might get lucky if one is all you need. $29.00 starting price plus shipping,,, cheap enough!!
Fender Braces have sold, going to a new home on a TB in Oregon.
