Ammeter Repair
Ammeter Repair
As I was transferring the instruments to my new dashboard, I noticed that the ammeter was rattling. I took it apart and found that something that looks like a paperclip had came off a pair of metal posts where it had previously been soldered on. This loop presumably creates a magnetic field that deflects the needle when a current is flowing.
Is the repair as simple as soldering this back on, or will I need to have it professionally repaired? If the latter, who is recommend in the UK?
Re: Ammeter Repair
Depends on your skill level. A little rosin core solder can do wonders.
Re: Ammeter Repair
If you do find your skills are not quite sufficient I would recommend John Marks of Vintage Restorations. He has a very good reputation for quality work and I am personally happy to use his services again...if he hasn't retired!
https://www.mg-cars.org.uk/vr/
Re: Ammeter Repair
I fear he may have done - he couldn't promise a date to repair my TC clock a few years ago.
Someone who gave me excellent service overhauling a set of instruments - including an ammeter - although not off an MG was Adrian Sidwell
Re: Ammeter Repair
John Marks restored all my TC instruments last year including building boost and water temperature gauges. I think he is being more selective these days.
Re: Ammeter Repair
HI
John E Marks retiered some years ago, may be 10 or so.
These following people rebuild MG Intruments
Chris Clark (& Greg)
The Hermitage
1 Pump Yard
Turnditch
Derbyshire DE56 2LH.
01773 550485
07858 746270 (Mobile)
and
Patrick Henry
vintageinstruments@hotmail.co.uk
07342 306690
cheers Carl
The Hermitage
1 Pump Yard
Turnditch
01773 550485
and
Patrick Henry
07342 306690
cheers Carl
Re: Ammeter Repair
Speedograph Richfield Ltd
1a Darlton Drive
Arnold
Nottingham NG5 7JR United Kingdom
Telephone:0044 (0) 115 926 4235. Fax:0044 (0) 115 920 9912
http://www.speedograph-richfield.com/
_______________________________
1a Darlton Drive
Arnold
Re: Ammeter Repair
I had all my TC instruments overhauled - and the dials repainted - By Speedograph Richfield. They needed two attempts to get the Speedo and Tacho correct in appearance and the green translucent illumination strips on both were creased. The needle fell off the speedo on the first drive and the tacho started at 2000. After they corrected these problems I haven't calibrated the tacho but it still seems very optimistic. This experience leaves me unable to recommend SR.
