TA underside of bulkhead/firewall/scuttle - What's this thing?
Post by Rob Reilly » Wed Jul 28, 2021 9:09 am
Found on my '37 TA.
Located on the underside of the firewall, in the center, in front of the tool box.
Held by one small round head screw and square nut, remnants of thin plywood attached by two flat head screws and square nuts.
What is it for?
Re: TA underside of bulkhead/firewall/scuttle - What's this thing?
Post by antijam » Fri Jul 30, 2021 4:49 am
In the absence of anything more original, could it be the remnants of some previous owners fitment of a 'scuttle mask' or 'wiring cover' board? I believe these were introduced on the TC but some owner might have thought it a good idea to have one on his TA - on the lines of this for the TC.
Post by Rob Reilly » Fri Jul 30, 2021 5:06 am
Ok that makes sense I guess, a piece of plywood, though it's a unique example of an improvement on a car that has had mostly dis-improvements in its life.
I'm curious about the fact that the bracket was attached through an oval hole in the firewall/scuttle.
This hole was punched, which looks like factory work, not a hack job.
Was this hole used for something else originally?
oval hole in center of firewall
oval hole in center.jpg (47.82 KiB) Viewed 1945 times
Post by Steve Simmons » Fri Jul 30, 2021 11:37 am
I don't know TA minutia, but It looks like what's left of the dash under-panel that would have been in a TC. I believe TA also had them but not positive. They are usually removed because they're more trouble than they are worth. Yours seems to have removed itself by rotting away!
Post by antijam » Fri Jul 30, 2021 12:11 pm
This shot of a TA engine bay suggests you may be right in supposing the hole to be original.....
....however, it doesn't seem to be serving any purpose. :?
cdrolshagen
Post by cdrolshagen » Sat Jul 31, 2021 3:35 am
Hi,
the hole is the front fixing point of the original plywood undershild
EPSON007.PDF
(691.08 KiB) Downloaded 323 times
cheers Carl
Post by Rob Reilly » Mon Aug 02, 2021 5:06 am
Ok thanks, it now appears that the plywood panel was original, but so many are long gone that it is a relatively unknown part. I had asked in a previous thread about some holes in the sides of the bulkhead, and now it appears they may have been used for brackets which supported this panel. Gradually the clues come together.
Post by Steve Simmons » Mon Aug 02, 2021 11:37 am
On a related note, I was on tour with several T-Types once about 10 years ago. There was a TF that was constantly shutting down over hundreds of frustrating miles. Once right in the middle of the Golden Gate Bridge. Another time on a twisty road through the Redwood forests. Sometimes only 30 seconds passed between breakdowns. I kept telling the guy to check the connections behind the dash but the panel was so difficult to remove and install that he refused, and kept checking other areas. Finally no one could take it anymore and he was left behind to find a repair shop. The problem was just a loose connection on the ignition switch, which was inaccessible because of the cover. Just something to think about if you plan to drive a lot of miles.
Post by Rob Reilly » Mon Aug 02, 2021 5:35 pm
Yeah, the way the steering column support passes through the round hole, ripping it apart was probably the method used on mine by some frustrated PO.
Perhaps hinged access panels or make it in two halves would have been better.
Maybe the factory thought there would never be any electrical problems. :lol:
