Brake Line/Pipe Size
loustaller
Post by loustaller » Fri Sep 03, 2021 4:52 pm
I am getting ready to make new brake lines for my '49 TC and was wondering, for those of you who have done this what size pipe did you use. I'm assuming 1/4" as that's what Doug Pelton said was the size the factory used and that's what the pipe nuts are sized for. Why did I think it was 3/16" other then I was having a senior moment! :lol:
Re: Brake Line/Pipe Size
Post by Duncan M » Fri Sep 03, 2021 7:29 pm
TC brake lines are 1/4 OD or 6.35mm. Fuel pipe is 5/16 OD
3/16 or 4.8mm was on TD/TF
https://ttypes.org/replacing-t-type-brake-pipes/
Post by Rob Reilly » Sun Sep 05, 2021 4:57 am
My '37 TA has 1/4" copper pipes. They appear to be all original. The curious thing is the ends are single flared, not the more usual double flare. I restored them and they work fine, no leaks. I wonder, as the TA was the first MG to have hydraulics, maybe double flare had not yet been invented?
Post by Ray White » Sun Sep 05, 2021 11:42 am
I found it quite difficult to get a really good double flare with 1/4" pipe.
Having said that; a bad workman blames his tools. :oops:
loustaller
Post by loustaller » Tue Sep 07, 2021 7:14 am
Thanks for the input and confirmation that the TC brake lines are indeed 1/4", that's what I will be fitting to my car.
Post by Ray White » Tue Sep 07, 2021 9:59 am
I was pleased with the armoured Cunifer brake pipe set for my TC supplied by Classic Car Geek.
There was a slight error with the length of one pipe but they were quick to put it right f.o.c.
https://www.classiccargeek.co.uk/store/ ... ducts.html
Post by Franz Tenbrock » Sun Sep 19, 2021 8:26 am
after the problem last days with the brake line i will make them new next winter
have you made double flare ?
are the new one you have bought double flare oder single
my old ones are single flare
i will make new ones with kunifer
Post by Ray White » Sun Sep 19, 2021 8:44 am
With respect, I wouldn't fit a single flare to any brake system. I believe it would be illegal in the U.K. but I can't be sure.
Anyway, better safe than sorry. ;)
i.thomson
Post by i.thomson » Sun Sep 19, 2021 10:12 am
Ray, I would doubt if the law would have anything to say about such things, before the accident anyway.
Ian
Post by Ray White » Sun Sep 19, 2021 11:59 am
Ian
Personally, I would rather not find out the hard way. :P
