Oil Pump
jddevel
Oil Pump
Post by jddevel » Sun Sep 12, 2021 8:59 am
Whilst stripping and cleaning the oil pump on my TC- so the early type with separate filter, I noticed that the oil groove inside at one end of the distribution cylinder is blocked off with what appears to be solder. I did not notice on dismantling which end the "blockage " was so need the following questions answered please. Which end should the blockage be- nearest the engine block or the cap. My belief is the cap end, Plus the blockages' purpose. My assumption is to force the groove to supply the necessary lubrication to the shaft.
jddevel
Re: Oil Pump
Post by jddevel » Mon Sep 13, 2021 9:55 am
Apparently this is not normal and it`s been suggested by Steve Baker that it may be a piece of bearing white metal that found its way into the grove.
Re: Oil Pump
Post by Steve Simmons » Mon Sep 13, 2021 11:24 am
It doesn't sound right to me. Someone could have been modifying it for whatever reason. If it was white metal, it wouldn't be melted in place though!
jddevel
Re: Oil Pump
Post by jddevel » Mon Sep 13, 2021 11:43 pm
Yes Steve. The curiosity of the MG cars. Have decided to rebuild the pump with new drive shaft and gearing, otherwise everything else seems "tight"
jddevel
Re: Oil Pump
Post by jddevel » Mon Sep 13, 2021 11:48 pm
One further point when discussing the subject with a machine shop was that wear can take place on the inner surfaces of the cast body that the gearing spins in thus reducing pressure. Anyone any idea what the original measurement between the ends of the teeth and the walls of the body may have been? I suspect a couple of thousands.
Tom Lange, MGT Repair
Re: Oil Pump
Post by Tom Lange, MGT Repair » Tue Sep 14, 2021 3:27 am
An excellent discussion of checking and rebuilding an oil pump is the information sheet supplied by Moss Motors with their kit. It is also readable by going to their on-line catalog, and clicking the icon by the oil pump kit - they give all the necessary specs to check.
Re: Oil Pump
Post by Steve Simmons » Tue Sep 14, 2021 8:58 am
I'm not sure where you're located, but Butch Taras in California does the best rebuilds. The clearances are all set properly, the correct circlip is used, and the lid is surface ground for flatness.
Re: Oil Pump
Post by Tom Lange, MGT Repair » Wed Sep 15, 2021 3:35 am
Steve - he's in Cornwall, UK. A bit far, I agree, but worth it for the best rebuild!
Re: Oil Pump
Post by Ray White » Fri Sep 17, 2021 12:04 pm
You could try Roger Furneaux - not that far from you. He machined my TC oil pump gears to fit.
Also... reasonable prices.!
jddevel
Re: Oil Pump
Post by jddevel » Fri Sep 17, 2021 11:36 pm
Thanks Ray. He did my axle.
ROGER FURNEAUX
Re: Oil Pump
Post by ROGER FURNEAUX » Mon Sep 20, 2021 2:15 pm
The Moss instructions make no special mention of the all-important circlip at the top of the shaft, but they and NTG show a modern one. Perhaps TL or somebody could remind us of the current thinking on this subject, i.e. are they too thin and liable to fail? Whilst I can get the machining done here in Devon/Cornwall, I don't rebuild the pumps, but assume that owners re-use the original clips.
Roger Furneaux
Re: Oil Pump
Post by Steve Simmons » Mon Sep 20, 2021 2:54 pm
From what I understand, the thin modern ones are high risk. I would not put one in my car for any reason. I've heard of several failures.
Mark McCombs
Re: Oil Pump
Post by Mark McCombs » Mon Sep 20, 2021 3:32 pm
Hi Steve,
When you say you have heard of failures of the modern clips, do you mean the thin circlip (open C shape) or the closed spiral type that I have seen?
The closed spiral type is like a closed thin keyring that spirals on then closes back into a solid ring.
Thanks, in the middle of doing thus assembly now so......
Re: Oil Pump
Post by Steve Simmons » Mon Sep 20, 2021 4:19 pm
It's been a while but I think it was the type shaped like a C. Moss and others used to sell them. I know the correct type are available from Butch Taras and FTFU.
jddevel
Re: Oil Pump
Post by jddevel » Wed Sep 22, 2021 12:02 am
I installed new gears but then found could not install original circlip and even partially prevented the drive shaft to turn. Replaced with the new clip and it does now. So what would you do now? I have not changed the drive shaft because no play and good gear on the cam end gear.
Re: Oil Pump
Post by Ray White » Wed Sep 22, 2021 4:30 am
I would say be very wary of the new cir clip. I think you need something more substantial on a par with the original or even put the original one back in. This may mean having the ends of the gears machined like I did. It is possible to reduce them by hand but it would not be as precise as machining.
I have heard some sad tales of expensive engine failures as a result of using the thin cir clip but have had no direct experience.
Mark McCombs
Re: Oil Pump
Post by Mark McCombs » Wed Sep 22, 2021 8:47 am
I am new to this assembly but after a near miss with this circlip I would not use a replacement open ended clip. As I see it, the driven gear is constantly pulling in against that clip.
FTFU has clever replacement that is a full circular clip that would have 100% of the clip in tension, without an open section that could spring open and allow the clip to depart.
Re: Oil Pump
Post by Steve Simmons » Wed Sep 22, 2021 2:04 pm
I haven't run into your situation, so I hesitate to offer advice. But I like the idea of machining the gear to accept the OEM style clip.
jddevel
Re: Oil Pump
Post by jddevel » Thu Sep 23, 2021 4:50 am
I like the idea of the clip from "From the frame up" however being in the UK probably cost me the proverbial "arm and a leg to get it posted. Especially as the likelyhood of a sensible free trade agreement appears to be diminishing. Apart from co-operation on the weapons and military front!!
Re: Oil Pump
Post by Duncan M » Thu Sep 23, 2021 3:57 pm
Some pics of these various retainers would be of interest. The good ones and the bad one.
