On my Lucas M418G starter motor (TC) the input terminal (negative) appears to have a very decayed rubber "grommet" between the cable connection and the end plate. Is that the case or is it some sort of insulation washer? Is it 45A on the Moss schematics?
https://www.moss-europe.co.uk/shop-by-m ... 36-55.html
TC starter motor
Re: TC starter motor
Yes, it's an insulating grommet and incorporates a rubber flange to protect the body of the switch. This picture shows it fitted....
Thank you. Sorted and order. Had another problem, Someone had installed a number of washers behind the copper ring that makes the contact between terminals when the lever/pull cable is operated. Result once cleaned up was permanently "contact made"!!!!!
Moss USA has the same rubber bit in stock for only $22.99
https://mossmotors.com/bush-rubber?assoc=137608
Thanks Duncan. On order from The Octagon Club here in the UK. Fortunately normally a lot less expensive than Moss.
