TC brake light switch
Unfortunately my memory has once again failed me. Whilst I realise where the brake pedal return spring is attached I cannot recall where the spring end NOT attached to the brake switch activating lever, is attached. It`s to short to be attached directly to the same hole on the bottom of the brake pedal. Unless the spring that came with the car was not the original.
Re: TC brake light switch
https://img1.wsimg.com/blobby/go/095cf0 ... 4501722957
From the Frame Up has the detail and drawing you need. Link above.
Tom
Tom
