side screen chrome trim
Please could someone check for me the width of the chrome trim that fits onto the side screens.
Thank you.
Thank you.
- Rickwilson
Re: side screen chrome trim
I am in process of installing new side screens on my TC. width of trim is about 11.5mm
I have an original set of side screens here, and they measure approximately 0.45" (varies between .43 and .52) which agrees with Rick's measurements.
- TC Side Screen Molding
- side-trim.jpg (69.52 KiB) Viewed 1443 times
Thanks to both of you!!
I notice that only the "spoon ends" type (TD/TF) is available and I have to say that I prefer the neatly mitred look as fitted to the TC.
I hope to be able to find an alternative that I can cut to shape but I suppose if all else fails the self adhesive stuff would suffice.
i too prefer the miter type but had to settle for the spoon end type. some of the pieces were too short and
would come loose from the fasteners. after a lot of adjusting, at least there mounted. i still do not like the gaps
at the corners.
at the corners.
Hi
i got the car with simple sidescreens, not really fine
no chrome trim
mostly i drive the car without this sidescreens
but i thought some month how i can modify my sidescreens
with tax and shipping 200 Euros for a part i doesn t need
now i had some time to think about it and i will buy some alu
1.000 x 11,5 mm, Aluminium, Blank, Bohr-Kennrille
Mit Bohr-Kennrille
Vielseitig einsetzbar
Schlichtes und modernes Design
Leicht zu verarbeiten
Multifunktional
1 , 65 Euro
only a few euros for all
i will drill some holes for the screws and then i will glue this here on it
Chrom Zierleiste 12mm x 12m selbstklebend universal Auto Chromleiste Kontur DE
all togehter 20 Euros
perhaps some day i will make it a little bit more original like
no chrome trim
Mit Bohr-Kennrille
Multifunktional
1 , 65 Euro
Franz. An alternative is self adhesive chrome trim.
https://www.carbuilder.com/uk/search?q=chrome+trim
If you use a translator you will see that it is the same as what I want to do
I will fix the aluminium trim with the existing screws and then glue the self-adhesive chrome trim to the aluminium trim.
![Laughing :lol:](./images/smilies/icon_lol.gif)
