Clutch adjustment of TC
bimmrr
Post by bimmrr » Fri Jan 07, 2022 12:41 pm
Hey y'all,
Just getting back into a 1948 TC ownership after 15 years away from one. Got into Healey's, which I still have one, but have come back to the first love for the TC. Nicely restored car but clutch travel is too far as much as I can tell.
I have ordered one of the TC owners manual reprints but not received just yet so do I recall correctly that the adjustment for the TC clutch travel is through the clutch cable with the adjustment being made with the nuts on the end of it ? Know this is a simple and probably obvious answer but do try to practice my rule of "if it aint broke don't fix it" and don't want to break it.
Mike
Re: Clutch adjustment of TC
Post by Ray White » Fri Jan 07, 2022 4:19 pm
The TC clutch linkage has a little chain and a return spring (no cable) and pedal adjustment is by a bolt against the housing. There should be between 3/4" and 1" free movement. When you look at it the adjustment procedure for the pedal becomes self evident.
Post by Duncan M » Fri Jan 07, 2022 4:21 pm
TB and TC you want 1 inch of free (pedal) travel. 1" is from Blower manual. That is assuming your friction material has not worn beyond adjustment limits.
Post by Ray White » Sat Jan 08, 2022 2:23 am
After the 1" free travel you then want a further three inches of pedal movement.
