Front hub grease seal orientation
Osiris610
Post by Osiris610 » Mon Feb 21, 2022 9:59 am
My question concerns the front hub grease seal, the rubber one that goes on the back side of the hub, against the inner bearing. The seal has a flat face and a contoured face containing a little encircling spring.
Which side of the seal goes against the inner wheel bearing, the flat side or the contoured side? It will fit either way.
Many thanks in advance for your help! Michael Whalen
Re: Front hub grease seal orientation
Post by Steve Simmons » Mon Feb 21, 2022 10:25 am
Hi Michael,
The seal goes in open side first. In other words, you should see the flat side after it's installed.
MG TC Front Hub Seal
Osiris610
Post by Osiris610 » Tue Feb 22, 2022 9:14 am
Thanks! That is just what I needed to know.
Happy Motoring, Michael Whalen
