spark plugs
spark plugs
Can the type of plug be identified by the depth of the threaded portion of the head? If so assuming it is half inch, (short) what modern types/ number is recommended for a XPAG in a Y type please. The existing are Champion L10s which I believe were updated to L86C but what substitutes are available?
Re: spark plugs
1/2" aka 14mm reach L10S plugs were also factory supplied in the TC. Heat range of L10S = L82C. Might be a bit cool unless you run around at high RPM's. L86C is the next heat range hotter (Same as L10) and more likely to work out with more reasonable RPM usage.
I have found the projected tip plugs to be no good in the TC, but some swear by them. L92YC = L86C, and L87YC = L82C in heat range.
