Breather pipe TC
Mark Robinson
Breather pipe TC
Post by Mark Robinson » Mon May 23, 2022 5:43 am
Could someone tell me which way up the tappet cover breather pipe goes please?
It measures approximately 4 inches before the first crease, approx 7 inches to the second crease and then a further 7.5 inches. So which is top and which is bottom?
Many thanks.
Re: Breather pipe TC
Post by antijam » Mon May 23, 2022 6:49 am
I can't measure the pipe at the moment, but this is how it's fitted to my car....
It looks as if the short length before the first bend is at the top.
Mark Robinson
Post by Mark Robinson » Mon May 23, 2022 8:02 am
Thanks Antijam. Yes, it does look like the short length is at the top.
Thank you for the pic, it's useful in other ways - getting a car as a box of bits is occasionally hard work!
Regards
Mark
i.thomson
Post by i.thomson » Tue May 24, 2022 2:30 am
It fits whichever way up allows the clamp to the bellhousing fit comfortably.
Ian
Mark Robinson
Post by Mark Robinson » Tue May 24, 2022 1:12 pm
Thanks Ian.
Post by Steve Simmons » Tue May 24, 2022 2:03 pm
Here's the breather on a spare engine in my shop. It's easy to take a photo when it's on a stand. The lower bolt isn't in it, but it's in the right position.
TC Breather Pipe
TC Breather Pipe
Post by Duncan M » Tue May 24, 2022 3:37 pm
In place, it should just barely drop down below the bottom edge of the chassis. Mine was painted white. Left is to front of car.
Mark Robinson
Post by Mark Robinson » Wed May 25, 2022 5:32 am
Thanks guys!
