hood to windscreen
hood to windscreen
Post by Ray White » Fri Jan 06, 2023 4:03 pm
I am trying to imagine how the long wing bolts will connect the hood to the corner pegs on the windscreen.
Although I have yet to finish assembly of the windscreen and fit it to the scuttle...and also yet to fit the hood... a photo of how the hood and screen come together would be a terrific help.
Thank you.
Ray..
Re: hood to windscreen
Post by Steve Simmons » Fri Jan 06, 2023 4:09 pm
I don't have a photo handy, but basically it works like this... The peg on top of the windscreen has a groove in it. You lower the top header down onto that peg, with the peg going up into the hole in the header. When you tighten the wing bolt, it goes through the wood header and into that groove, which prevents the top from coming off the peg.
Post by Ray White » Sat Jan 07, 2023 2:50 am
My header is new so I will need to make some holes in it. Are the holes lined in any way and is there something like a nut that needs to go into the wood for the wing bolt to thread onto?
Post by stephen stierman » Sat Jan 07, 2023 4:07 am
There is a socket as I recall that lines the holes. Moss shows it for the TD-TF but I suspect it is for the TC also or check From the Frame up.
JonnyP
Post by JonnyP » Sat Jan 07, 2023 8:16 am
There are two plates welded to either side of the front bow of the frame which have holes in them to provide the location for the holes in the header and also have threaded bosses in to which the wingnuts screw.
Post by Ray White » Sat Jan 07, 2023 1:24 pm
I will have to check that my hood frame has the threaded steel plates. It came separately with the car; not attached to it.
Post by antijam » Sun Jan 08, 2023 2:43 am
This slightly blurred shot shows the left corner of the hood prior to being pulled down onto the screen and secured with the wing bolt....
.....does this help?
Tim Jackson
Post by Tim Jackson » Sun Jan 08, 2023 2:52 am
Have a look at page 46, parts #21, #37 and #38
https://storage.hyperportal.org/anglopa ... etjHpKyQ__
hood fixing.JPG (14.89 KiB) Viewed 3755 times
1946 TC0999 / XPAG 1638
restore note
Post by Ray White » Sun Jan 08, 2023 12:48 pm
Probably simpler that it appears. A bigger issue I am having is with poorly made screen frame brackets. The holes are all out of alignment. I have resorted to drilling and tapping 2 BA holes in un drilled brackets. I expect many other restorers have had the same issue.
I really appreciate the advice and help given by you guys.
searunner
Post by searunner » Fri Jun 23, 2023 12:36 am
https://www.dbraun99.com/MGTD15470/Weat ... index.html
David Brawn MG TD TOP was same as late MG TC on My TOP works I followed His foto album -Helped me a lot
EARLY MG TC 0433
https://photos.app.goo.gl/79ip3wZkx5qSf7p46
https://photos.app.goo.gl/98Ews7iFVrHeLK1m9
