Oil catchment tray
Oil catchment tray
Sources for the catchment tray to attach to bell housing please. Have contacted John James but covering the bases.
Re: Oil catchment tray
make it by yourself,
it is easy ;-)
if you can weld
will cost less then 3 Euro
it is easy ;-)
if you can weld
There's a guy in the USA who sells them on eBay for $70, as seen here: https://www.ebay.com/itm/266575035014
Here's another ad in the UK at about the same price, but not sure how old it is: https://www.mg-cars.org.uk/imgytr/store ... rays.shtml
why not replace pan gaskets and front seal. much easier. and problem solved with
proper installation.
cheers
stu
cheers
stu
Because the pan gaskets and the front seal are usually not the problem, it is the rear slinger that causes the major leak that this thing was designed to remedy as a stop gap band aid measure.
